Originally Posted by oledoc2u
Les, as I noted on your other post....I push things really hard, and I do believe a lot of the "looseness" I feel pushing hard through a turn is the fact that everything, meaning the bushings, are just giving in too much...too bad there isn't a ready-made poly bushing kit for these cars...I don't play on a track anywhere near as much as you do, but once in awhile I will go out and throw her around a bit...just seems loose...I am going with some firmer shocks...but the give I am feeling is in the suspension itself...shocks should help with the roll...but, again...not doing this much to worry about it...
doc there is a poly kit for the r170 but coat about 2k$! look at how the front sway bar is designed . really poor in my opinion. way to much room to move the bar around.
