Re: Alarm going off on its own! interior light flickers / unlocking randomly if driving!!
Originally Posted by fastfunfor2
The srt wing on the hatch is prone to leaking. On ours, the gasket that seals the rectangular panel under the wing was letting a lot of water through, where it runs behind interior panels and collects in the two trunkwells.
If your central locking pump and alarm control module get wet, a lot of things can happen.
Crawl under the rear of the car and locate the rubber plugs on the bottom of the trunkwells. They will probably be oversprayed with black undercoating, but you can pop them out with a pliers and flat screwdriver. Just pray that you don't get a stream of water, because if you do you have a bunch of issues to deal with.
I did a repair thread with pictures
https://www.crossfireforum.org/forum...you-trunk.html
I definately did take into consideration of your post.... I just figured to start with the problem being the siren alarm as a ton of people posted about it and it made sense when I was able to pull fuse # 9 and then everything shut off and didn't come back on. It was the same symptons as one would expect when disconnecting that fuse but it was a couple of days later ( today ) when the side marker, tail lights and fog lights randomly came on and would not go away... having that happen I realized it was time to look into this by taking to the dealer.
