Old Jun 30, 2011 | 12:29 PM
ThatSweetSRT6's Avatar
ThatSweetSRT6
Default Re: Alarm going off on its own! Interior light flickers / unlocking randomly if driving!!
Originally Posted by rekcah
The Central Locking Pump/Security System Module is easy to replace. After you take off the interior of the trunk and remove the Styrofoam insert, it just sits there in a foam cover. Pop off the air hose assembly, disconnect 4 connectors and that's that. 15mins tops.
You might be able to just disconnect the black 18pin connector on the Security System Module to stop the siren from randomly going off. This connector has the siren signal output. I have not tried this. I would but I dont have this problem and it's still raining.
MB's solution is to turn it upside down and put it in a bag.
This is fantastic information, thank you so much.
The Mercedes central locking module can be had for less than $360 new from Autohauz, not in stock at the moment but ....
Part number is 170 800 08 48 not 17080000848 ( too many 0's)
Get the idea of more than one module out of your mind , there is only one.
I am sure the foam can be dried out, it may take a while.
Compare Prices Mercedes Part 1708000848 Vacuum Pump Central Locking System | Everything Benz
Used Vacuum Pump For 2002 Mercedes Benz Slk230 Needed
Thank you for the links! I have to ask though, isn't there 2 modules back there though? The Central Locking Pump Module that made my side lights, tail lights and fog lights stay on?? and then theres the Alarm Module that started all the problems from the get-go that made my alarm go off erractially when I thought it was the siren alarm but apparently its the Alarm Module in the trunk? let me know because I thought it was two modules... if not, why would the service advisor say both modules needing replacement? in reality I'm assuming that the Locking Pump Module is actually the entire problem part here this whole time? and of course I will need to take the fixed wing spoiler apart and re-seal those area's and make drain plug(s) at the bottom of the trunk wells, great idea I must say!
