Old Jun 30, 2011 | 12:41 PM
onehundred80
Default Re: Alarm going off on its own! Interior light flickers / unlocking randomly if driving!!
Originally Posted by ThatSweetSRT6
Thank you for the links! I have to ask though, isn't there 2 modules back there though? The Central Locking Pump Module that made my side lights, tail lights and fog lights stay on?? and then theres the Alarm Module that started all the problems from the get-go that made my alarm go off erractially when I thought it was the siren alarm but apparently its the Alarm Module in the trunk? let me know because I thought it was two modules... if not, why would the service advise both needing replacement? in reality I'm assuming that the Locking Pump Module is actually the entire problem part here this whole time? and of course I will need to take the wing apart and re-seal those area's and make drain plug(s) at the bottom of the trunk wells, great idea I must say!
The alarm goes off because the Locking Pump Module gives the wrong signal or fails to give the correct signal to the security system due to the moisture problems. Wrong signals or not the true signal triggers the alarm which is under the cowl on the firewall.
Seems to me that these cars need a sump pump fitted in the trunk.
