Re: Alarm going off on its own! Interior light flickers / unlocking randomly if driving!!
Originally Posted by ThatSweetSRT6
Another update for you all:
My project now is to take the fixed spoiler wing off and re-apply new o-rings. Someone mentioned RTV seal, I know about that stuff. Would it be best to apply that in replacement of the o-rings or would it be best to use BOTH the RTV Seal and the o-rings for maximum protection from water?
Also I plan to plastic wrap the new Module, does Mercedes have a special made bag for the module that I can buy?? please advise. Thanks all, you guys are really rare and I'm SO thankful.
A heavy duty plastic bag will be fine. Use the RTV or a silicone sealant, don't use too much and the O-rings. You can use any suitable O-ring, buying from a dealer will get you the same ones as you can buy, but they will cost more, much more. Just get the correct size.
If you added holes they should not be under the pump unit as the bag may cover and seal them. Others removed the plastic plugs in the well.
