Old Jul 2, 2011 | 07:01 AM
oledoc2u
Default Re: Help!! Clutch won't engage, can't shift gears
$2700 for a clutch and flywheel is rediculous. Should'nt cost more than $700 incl. clutch, release bearing and flywheel plus install of $500-$700.
True, but you don't how much damage was done inside the bellhousing. If they had more hours in cleaning up the mess of a 100 mph shrapnel explosion, plus, a flywheel which usually isn't needed, it would cost more. Even so, they got you for a cool grand kid...no more coasting....as the clutch probably already had a problem, broken spring, whatever, and with it freewheeling, it probably came apart, rattling around in there, and once you reingaged the clutch all hell broke loose...who knows, but keep the clutch engaged while coasting, just kick it out of gear....now go make us proud...
