Actually part # 05161797AA is the kit that includes the motor, see below:
Motor Kit, Spoiler
Kit Contains:
1 - Motor Mount
1 - Motor
4 - Damper
2 - Collar
1 - Gear Wheel
4 - Nut
2 - Lock Washer
2 - Flanged Bearing (MFM-0912-08)
1 - Flanged Bearing (GFM-1517-04)
2 - Cable Tie
2 - Micro Switch Assy
.2 - Screw
2 - Rubber Support
2 - Bracket
1 - Connector
1 - Screw
Your part # (05161796AA) is for:
Drive Shaft Kit, Spoiler
Kit Contains:
1 - Left Drive Shaft
1 - Right Drive Shaft
2 - Locking Pin
I'll do some searching, but I think this is going to be an item you'll have to call a salvage yard directly about if you want it used.
Here's a copy of a TSB relating to the spoiler, which is where I got the part # info. It also includes in-depth instructions on removing and servicing the spoiler.
http://www.crossfire-garage.fr/docum...2004-10-05.pdf
thanks for everything bud! I did buy one second hand and it was unfortunately already toast..
the part# was a typo .. I did have the pdf but I am having dificulties finding the part on the web and in the US. sorry about the thread hijacking.
