Old Jul 5, 2011 | 02:20 PM
booaw1's Avatar
booaw1
Default Re: Suspension problem
Originally Posted by MikeR
The only thing I can think of that MIGHT cause one side to be higher/lower than the other is if your shop did not get the springs in the seats on the bottom and in the top spring pads on one side..... presuming that the car was level side to side before the spring/shock change.....
I did it all in my garage so I made sure they were seated the second time. And they were level as far as I could tell before! haha
Originally Posted by JHM2K
Check EVERYTHING... even things as simple as sway-bar mounts. It's unusual that only the passenger side would drop 1" lower, if the install method was identical on both sides. Also, make sure the shocks are torqued to roughly 30ft/lbs...
Spring pads, once in place, don't move. And the springs settle a TAD but nothing crazy like an additional inch. Mine only settled 1/4", if that.
Which Bilsteins did you order, out of curiosity?
Heard that, about to go out and do check it all again. And they are Bilstein HD's.
Thanks for the quick replies
