Old Jul 9, 2011 | 09:31 AM
onehundred80
Default Re: Wanted: Mercedes C320 Airbox
Originally Posted by joejones
Which covers will fit a Crossfire?
Parts to do this modification are;
Mercedes engine cover #A 112 090 1101
The front part of this two piece cover is part #A112 010 0467
Intake tubes, left #A112 094 35 82, right #A112 094 34 82. These require the OEM adapters to be removed from the radiator support and to be modified so they fit through the radiator support hole which is too small.
Filters, K&N's #33-2181
74 mm Throttle Body, Mercedes #A113 141 0125
Throttle body O-ring #05102933AA, Mercedes #3059970345. Or a Viton O-ring #151, 3/32" x 3 3/16" outside diameter
The larger (3") MAF, Mercedes #A 113 094 0048. Using the original OEM MAF sensor.
Donut seal for engine cover to MAF unit, Mercedes #1120940180 (If original is damaged)
