Old Jul 10, 2011 | 12:20 PM
  #38 (permalink)
TerryR's Avatar
TerryR
Default Re: What's the going rate for a new Crossfire key?
Originally Posted by jammer
124.99 comes programmed. I've purchased two. They are brand new original part. go to:
https://www.remotesandkeys.com/Produ...ductCode=3191A
You need to supply your vin# and milage. They come from Germany to a dealer. The ignition starts beautifully but sometimes the remote doesn't work until you do the following. Then all is good. I've done it twice:
The switchblade remote key can lose it's synchronization if the buttons are pressed too many times when not in range of the vehicle. If this happens the solution is to simply resynchronize.
Resynchronization:
  1. Insert key into ignition. Don't turn it.
  2. Press the lock button on the switchblade remote key twice in 2 seconds.
  3. Turn the key to ON or RUN within 30 seconds.
  4. Take the key out. Exit vehicle and have the doors closed. Test the remote.
They have keys and remotes for almost every car make and model.
Jammer, This is who I used also. My cost was $135 incl shipping. Got mine in about 10 days. No problems whatsoever with the key, worked first time.
Proof of Ownership required.
