Re: steering wheel removable
C_Plunkett is correct. remove neg battery cable first... etc... There are specific instructions in the Crossfire Repair Manual... If you are replacing the wheel with an aftermarket wheel, once you remove the squib for the airbag, you will have to use the DRBIII scan tool to turn the airbag warning light off on your dashboard. I can only assume this is why you are wanting to remove the steering wheel...
