Old Jul 16, 2011 | 10:38 AM
onehundred80
Default Re: oxygen sensor problem
Originally Posted by the.Santorini
i've replaced both downstream sensors. still getting P2096. being its reporting the mixture is too lean, that might also suggest a messed up vacuum hose somewhere. im currently going through the manual and trying to map out the hose routes so i can check there condition. would anyone happen to have a handy photo pointing out the hoses by any chance? if not, i will figure it out and post something for others to reference.
I see you had the throttle body cleaned some time back, is it possible that the TB gasket and/or the seal below the MAF are leaking?
Or is there something wrong with the MAF sensor?
Are the vacuum lines in this area loose or broken?
