Originally Posted by dtinker
roctech;
Did you have a chance to try my fix for the bird droppings on your car? The faster you neutralize the acid the better. It will just keep burning the paint if you don't get it all off. Let me know if it solves the problem.
Thank you for the tip, I just tried it in the hot sun, I used a couple of alcohol rubs I had in medical kit and applied wet paste with a wet towel over it. Thirty minutes later i cleaned up paste carefully with water and micro towel. The hood was very hot , black car in the sun, however I applied polish to area rubbing it aggressively and then waxed. It took me the next ten minutes to find where the spot was, it is faded 90%. Unless you knew it was there and looking you would never spot it. The next time I detail the car I will try rubbing the remainder out
I would have to say that is a great Tip. Thank You again, and anybody with bird stains give it a try, very easy fix.
