Re: turns over but trouble starting
Forget the fob entirely.
I think it's a fuel pressure problem of which there has been a lot lately.
Get the fuel rail pressure checked and do a leak down test. Fuel pump check valve or fuel pump pressure are my guesses.
When you put the key in the ignition and turn it on what would happen if you waited 10 seconds before going to the start position? Can you here the pump running and for how long?
