Old Jul 20, 2011 | 08:52 AM
Rossco's Avatar
Rossco
Default Re: turns over but trouble starting
Forget the fob entirely.
I think it's a fuel pressure problem of which there has been a lot lately.
Get the fuel rail pressure checked and do a leak down test. Fuel pump check valve or fuel pump pressure are my guesses.
When you put the key in the ignition and turn it on what would happen if you waited 10 seconds before going to the start position? Can you here the pump running and for how long?
Thanks for your quick replay much appreicated.
I'm in the office at work at the moment so I will try leaving it in the ignition position for 10 seconds before starting .. will the fuel pump start and build pressure in the ignition position?
Thanks for your recomendations to look at the fuel pump check valve and fuel pump pressure. Can either of these be fixed with out the need of buying new units?
