Old Jul 20, 2011 | 09:11 AM
onehundred80
Default Re: turns over but trouble starting
Originally Posted by Rossco
Thanks for your quick replay much appreicated.
I'm in the office at work at the moment so I will try leaving it in the ignition position for 10 seconds before starting .. will the fuel pump start and build pressure in the ignition position?
Thanks for your recomendations to look at the fuel pump check valve and fuel pump pressure. Can either of these be fixed with out the need of buying new units?
The check valve is in the fuel pump and not repairable. When the fuel pump fails it is time to get a new one. The filter fault is a possibility and are quite cheap.
I would not go back to that garage, they should have cured it the first time, why did they not know it was not fixed.
As I said get the fuel pressure checked and the leak down test. If its the pump this will tell you. Presuming you do not have a leaky injector.
