Pulling to the right, can be several different things. Brake rotors, bad or worn out pad, low tire pressure, and last but not least, the steering stabilizer. There are suspension parts as well, that would allow the car to pull right. Steering stabilizers or steering dampners, are usually bad. Look under the car and see if the cylinder is leaking. If the stabilizer is bad, it will let the car wonder, or pull along with the off camber road surface.
