Old Jul 20, 2011 | 11:54 PM
Valk
Default Re: turns over but trouble starting
I have just recently had this same problem.
Did a lot of searching here and found this write up to probably be the best match to what I am experiencing and sounds like your problem as well.
Mine began acting up last Friday but today it finally caused the car to barely even run but I made it home....but just barely.
No CEL or codes but not enough fuel supply to run normally.
I'm getting a new fuel pump and fuel filter hopefully this weekend.
Will try the filter/regulator first and test the fuel pump to see if it is the problem.
Check this out: https://www.crossfireforum.org/forum/607808-post34.html
