Thread: Fuel trims
Old Jul 21, 2011 | 04:29 PM
downwardspiral's Avatar
downwardspiral
Default Re: Fuel trims
Thanks man, even at idle? If so then I'm adding a lot of fuel just for idle and low load cruizing. If I could crank up the fuel pressure and watch the LTFTs I would know for sure if + was indeed adding fuel.
Anyone else watching their fuel trims in this heat?
Edit: Downward I re-read your first sentence. My AFRs are at 14.7 as they should be in closed loop. So I am thinking it's just adding (?) to keep stoich, not a safety measure.
I re-read your original post a couple times too lol.. That is strange, and it does seem as though the higher the positive LTFT value, the more fuel is added. But I am pretty confused now myself after reading a couple posts on mercedes forums saying contrasting things. However, I did notice a couple places saying trims should not exceed +/- 10%.. and that trim issues tend to be connected to O2 sensor or MAF issues. Assuming positive means more fuel.. If your MAF was dirty the heated element would stay hot, especially when the air in the intake track is moving slowly.. leading the engine to beleive less air is entering it.. So less fuel would be injected. If the engine is in closed loop, and 14.7 is desired, the amount injected would not be enough and the trim would increase to compensate. Once the car was in motion and under load, the increased air velocity would theoretically cool the sensor and the trim would decrease. I am thinking of it like a car overheating in traffic due to the radiator being deprived of moving air.
