Thread: Rs Penta Wheels
Old Jul 23, 2011 | 02:16 PM
shedman's Avatar
shedman
Default Re: Rs Penta Wheels
Originally Posted by UK DAVE
Hi All,
Just Need Some Feedback On Aftermarket Wheels ...i Have Rs Penta Wheels 19x 8.5 Offset 32 Up Front And 20x 9.5 Offset 38 On The Rears I Did A Test Fit Before Fitting The Tires I Think The Rears Will Need Some Hub Centric Spacers To Push Them Out Towards The Wheel Arch As I Dont Think That Will Be A Problem..but The Fronts Seem To Be Very Close To The Wheel Arch Lip I Know It Will Toe In Some What Once The Tires Are Fitted But It Will Be Close So I Am Taking Them Back To The Store For Them To Fit The Tires As They Recommended These Wheels For The Crossfire So If There Is A Problem They Will Have To Sort It Out...so My Question Is Have Any Of You Guys Done A Similar Setup..
Thanks..dave.
Hi, i am running 255/30/20 x 9.5 offset 37 on rear with no problems .The fronts i have got 235/35/19 x 8.5 offset 45 with a 16mm spacer which brings offset down to 29 .I do get occasional rubbing on outer tyre wall over extreme bumps.I am thinking of going to 12mm spacer to take wheel in enough so tyre has clearance on wheel arch and it should still clear the suspension nut.I am sure with the extra 3mm clearance you have over me you will be fine.
