Old Jul 23, 2011 | 03:27 PM
  #110 (permalink)
BRappaport's Avatar
BRappaport
Default Re: Roadster rear window problem solved?
Originally Posted by aftcg
*******UPDATE*******
Try Rhino Glue. Its a thick cynoacrilate. I should have tried this stuff first! I have been using cynoacrilate (CA) glue for years with my radio controlled airplane habit. Crash, rebuild, crash, rebuild...
Well. Its been just about a month since the repair, and I'm 100% satisfied. It took 20 minutes all said and done. And cost about 20 bucks. Been parking it in the sun for about 3 days a week, in the Houston heat and its working out great! HIGHLY RECOMMEND.
However, you will spill a bit here and there so make sure you have a thick drop cloth, or old moving blanket. If you do get it in a place where you don't want it, you can undo it with a solvent. You should buy this before starting this project.
CA Solvent:
TowerHobbies.com | US-1 Hot Stuff Ultra Super Solvent 2 oz
SOOO HAAAAAAPYYYY!!
__________________________________________________ ____________
Hi aftcg,
Can you please update us on how you performed your repair with "Rhino Glue". What prep work did you do first and how did you apply it.
Thanks
Ben
