Originally Posted by Mr. Max
Sounds like a solid plan. I would mod the original also. If you screw in up, oh well, it's just going to take up shelf space anyway.
Luckily I have a spare to experiment with!
Originally Posted by 32krazy!
there was a member who used aircraft quality rivets and repaired his oem pulley. with the groove on the inside of the pulley 62 mm isn't likely. 65mm may be doable
Yes, I'll try for 65mm and see how that holds up.Thanks.
p.s Managed to acquire a tin of Mobil Jet Oil 254 from SkyGeeks.Com recently. 1 x Quart tin. Great service from those guys. MB here in Oz wanted $157 for 125ml (4.22 fl.oz). I got 946ml (31.99 fl.oz) landed for under $50! Go figure.
