Originally Posted by LenardCF23
they look great! im trying to change my parking lights. where did u buy ur parking light and how do u install them?
I bought all of my LEDs from superbrightleds.com
They parking lights are easy IF you have 45 degree needle nose pliers. Without it's quite difficult.
Basically to install them just pop the hood and look at your headlight from the front. In the top corner of your light you can see the little bulbs for the parking lights. Look on the other side of the headlight (inside the hood) and find them. (Little grey piece with tabs on it). Take the pliers and grab the grey piece and rotate them counter-clockwise. They're twist locks and rotate about 90 degrees. Once you get them out simply pull the bulb out and put the new one in. They are the 194 style wedge bulbs (same as map lights). I tried to fit the 9LED wedge bulb in there, but only a 6 LED will fit. I used the 9 LED headlights for my map lights instead.
Lemme know if you have more questions.
Regards & good luck,
Eric Henderson
