Old Jul 28, 2011 | 10:57 AM
BRappaport's Avatar
BRappaport
Default Re: Roadster Rear Window Fix
Michael M,
Thanks for the reply and your comments on fixing the rear window.
Please keep us all posted on the progress and success of the fix.
I have not done mine yet, but my situation is very similar to yours.
The glass and fabric on mine is seperating the same as yours, sides and corners delaminated but the top and bottom edge still intact.
You mentioned that you used PVC Cleaner...did you use that after you razor bladed the glass? Also, did you use the PVC Cleaner to clean the fabric also?
Also, did you spread the 3M Window Weld adhesive on the glass only, or did you also put it on the fabric as well?
I believe the success of the fix working and holding is in the details of the preparation done to the glass and fabric. Since the delamination and seperation seems to be between the adhesive and the fabric, I was wondering whether you worked the adhesive into the fabric before pressing the two surfaces together.?
Looking forward to your comments.
BTW, did you try lifting up any of the fabric that was still secure to see how well stuck down it was?
Regards,...Ben
