Re: New photos of Mandrus Wilhelm
Quick update after a few weeks of driving and everything settling. I was more worried about front clearance than back but apparently I should have been looking at the rear more. On both sides I have marks at the top inside from rubbing. Anyone else see this? I am running the eibachs so I assume I'm slightly lower and softer than JHM2K. Will be getting alignment next week but my camber isn't off by that much that I can tell. Camber arms are set longer than stock. I think it is uphill turns or into steep parking lot entrances etc. Where body roll is to the compressed side and then compression as the wheel comes up the bank. I have had a couple BANG! Bumps etc. and was expecting more because of lowering but now I'm kinda concerned I may not have done something the correct way. Drivers side is just a scuff but passenger side is shiney. Will prob pull tires to get a better look this weekend.
Springs would play biggest part in this no? I feel like there isn't much shock travel but I trimmed the bump stops and such. I could set the konis stiffer but the ride is a bit rougher/louder already.
