Re: NW DCAI Installed... Problems
im not real familiar with the n/a but it sounds like you might have messed the maf up. it tells the ecu how much air is being ingested. so if its reading incorrectly you could be getting the wrong input for afr causing a bog or lag. the whistle sounds like a vacuum leak which would cause a high rev and high pitch sound
