Old Aug 1, 2011 | 08:21 AM
redeagle's Avatar
redeagle
Default Re: Not exactly what I expected from Crutchfield
I did not hook up the Bluetooth - bought this unit because it was in the outlet clearance section at a great price and no satelite add on - unable to help there.
The Ipod/USB and Aux cable I simply ran under them out by going under plastic passenger left sided panel just above that little net holder - just gently pulled the plastic panel off the carpet and pushed in on the carpet and stuck a finger up the grab cables, nothing to unbolt or disasemble. I did take a short length (2-3") of black plastic tubing split it up the middel and placed the two cables inside to act as a protective sleeve for the cable against any rubbing from the tight fit under the plastic edge. The cable and devices store in the little black net and stay there since you can control the Ipod and flashdrive devices from the headunit. Almost invisible and no front wire getting in the way of the stick shift I like the clean look of the HU - no flashing red green or blue lights.
