Old Aug 1, 2011 | 11:14 AM
onehundred80
Default Re: E Z sensor TPMS and Crossfire
Originally Posted by MikeR
Just to be clear... I am not saying that the EZ sensors dont work in our car..... just that the local tire shop can't seem to program them to the car.... which means you have to go to the dealer and pay them to program them..... since I have working OEM sensors I was just trying to find a solution that didnt require the dealer programing....
The EZ-sensor #33000 should work in some 05 na's and some 05 SRT6's. They should be fitted with the optional metal stem, which replaces the standard rubber stem. The stems are screwed in place to the sensor body.
The EZ-sensor can be programed by the tire dealer using the EZ-sensor programing tool. If they sell the sensor they should have the proper tools to complete the job, as the old programing tools are modified using new software.
The EZ-sensor can only be used to replace OEM sensor #56053030AB and AC, which can also be replaced with Schrader sensor #20066. Most Crossfires use Schrader #20028 as replacements. There is no EZ-sensor to replace this as yet that I have found.
Various OEM part numbers for the Crossfire are mentioned and this causes confusion. I cannot be sure of the OEM part numbers I use as different sites come up with different numbers.
