Originally Posted by dinasrt
Do we need to buy a "BeltWrap kit" or PSK from Rob with the new EC pulley? Is it the same as the 178/181PSK, or does it have stock size or different size pullies and a different belt length? I don't see a Beltwrap kit for the code3 on his website is why I ask. This has probably been talked about thousands of times, sorry guys.
The pulley saver kit is designed for the crank pulley replacements. Since this is a supercharger pulley, you don't need the pulley saver kit.
However: some have installed the PSK with a Code3 pulley simply because the design of the PSK gives about 10% more wrap around the supercharger pulley, thus giving the belt more grip and should have less slippage. I've been considering doing this myself. If I get my pulley machined down to 63mm, I will definitely do this as you'll need the extra grip.
