Originally Posted by wstacyok
Also that does not explain the radio not working, I thought maybe fuses or relays where blown but I could not find any. Unless I have missed some. Thank You.
It could have blown the fuse in the back of the radio. When you pull the radio out, there is a 10 fuse plugged in the back of it. It's possible that occurred. You should have then use the radio removal tools, pull out the radio and check that fuse as well.
Good luck.
