Re: Center Console LOCKED
I am sure you are aware the it is a air controled vs. an electric sytem on most cars. The module is is in the trunk. BUT if everything else is working -- door locks, trunk lock etc. I would bet that an air line to the center console has worked lose. You might wanted to check out the repair manual and see how you get to that rascal. Just my thoughts on the issue.
PS I read the above responses after I wrote this so try the key and see if it works the lock on the console. That is a great idea and a much simplier fix. I need to remember that.
