Old Aug 2, 2011 | 09:05 PM
dinasrt's Avatar
dinasrt
Default Re: Lot's to do (typical probs)
Originally Posted by velociabstract
No, I didn't fix it. I'm not sure how. I'd hate to try and make it worse or ruin it. I found a link to a tool to re rivet the pulley but not with the rivets. I'll keep investigating the problem to come up with a solution .... or replace it if I can't fix it.
Les
I don't have a clue either Les, that's why I asked. I thought maybe you found a master machinist down there somewhere that knew his $hit. I'm trying to learn about these SC pulleys because I'm considering EC's new 65mm pulley they will have out soon. After reading 180's above post I'm having to re-evaluate. I've heard from some that the SC pulley can sometimes have driveability issues, like kicking in a bit harsh; is this the rivet issue? Perhaps it was just an isolated few that had issues I don't know, just trying to make the right choice between the new 65mm SC pulley and an ASP 178 pulley. I know; it's an old debate. I'd also like to know how EC is doing it better than the C3, or is it just a copy? Will have to wait and see.
