Re: purchasing my srt6 yet another hiccup
Originally Posted by boocher13
Wow now I'm wondering if the tech misdiagnosed the problem.Originally we were told that the fan wasn't coming on when it should so they said they had to test the sensor relay and fan itself.About an hour later they let the salesman know it was the PCM,they had to order it and it would be there in 3 to 5 days.The chrysler dealership that diagnosed the problem is not the one I'm buying from since it was about 50 miles away.I'll definitely mention the IC leak possibility.Back to my original question I know some vehicles after their comp has spit out a code and it has been cleared there is a time period you need to drive the car/put in a certain number of miles to allow the comp monitors to cycle.I know emissions stations here wont pass your vehicle until the comp is reading all cycles performed.I ran into this problem with my explorer,will replacing the PCM cause a comp reset?
Also---This light is not only LOW COOLANT but cooling system problem (double duty)---A BAD fan which will have the temp increase will trip this light. Techs will misdiagnose this car all the time. Not enough time working on them due to the fact not that many made of them. The fuse I'm talking about is the outside one in the group of three---one 200amp & two 50 amps---Check it first---Next question is why it blew. I bought and sold cars this is why I had six XFs. When I replaced the fuse all was fine for 1000s of miles in both cars, so I never saw any other problems. I am still in touch with one of the owners of one of the cars and he still has had nothing else cooling system related---so no answer on why. MAKE then replace the fan not just the fuse---OVER 50 amps were pulled for SOME reason---Maybe overkill but NOW is the time---The dealer will not help in 6 months---Jimmy
