Old Aug 5, 2011 | 11:19 AM
JimmyJames's Avatar
JimmyJames
Default Re: purchasing my srt6 yet another hiccup
Originally Posted by SRT6_Roadster
To answer your question about the computer. Yes like any OBDII computer when it is reset (and it will be) you must meet certain driving conditions prior to the computer being ready for emissions testing.
If you google you can find out what tests the computer is looking for.
Yes---100%---must reset what is called the monitoring systems---much like a teacher calling roll back in school---everything must say "here"---takes a couple of drive cycles---PCM must see a few different things. Good luck---I still think your PCM is just fine---it is however getting a BAD signal---there is a difference---Please drive to the stealership and fine the fuse box. About half way from the battery and the coolant reservoir; on the shock mount. CORRECTION it is the outside one toward the airbox---just checked---you have a 200 amp and two 50 amps in a SRT. It's the outside one that controls the fan. THEN show them up!!!! God bless them!!!!
