Old Aug 5, 2011 | 11:39 AM
PNA's Avatar
PNA
Default Re: New "used" Radio for my '04
Thanks for the info.
Does anyone know is the base radio can be swapped for the limited one and still utilize the OEM amp? I have the radio from my '05 base and would like to put it in my '04 limited because of the visibility on the LCD, just wondering if anyone has blazed the trail before me...
I asked / tried to find that out earlier this spring. I wasn't successful. I'm not sure if it's the same radio / amps etc. and can drive the back speakers in the limited or not. I tried to find this out via some web searching and came up short. I'll see if I can find out more.
One thing to consider is to just try it. Look at the back, look at the ratings and compare then on the stickers located on each unit and see if they match up. Also, it's so easy to swap them out you could just make the switch and see what happens.
I'll repost if I find more info. Good luck.
