Old Aug 5, 2011 | 01:00 PM
JimmyJames's Avatar
JimmyJames
Default Re: purchasing my srt6 yet another hiccup
Originally Posted by boocher13
thanks for the info does anyone know the parameters you have to put the car thru to clear out all the monitors? I remember with my explorer there was a certain set of things you could do to avoid having to actually drive the car for 500 miles before they cleared out.I'm more concerned with the possible IC leaking.The same coolant that is circulated thru the engine and radiator is shared by the IC correct? So a pressure test should detect an IC leak since there is nothing leaking to the ground.
PCM is looking for cold start (open loop) then closed loop, acceleration/ deceleration between different speeds, etc---every car program is a little different. 500 is a lot---did not get a good mix is my guess. When I had my repair shoppes, 30 to 70 of city and hwy---more city, cleared everything. If the coolant bottle is full, you do not have a leak: can't---coolant is full---You are correct---shared pressurized system for both. To check: Fill the bottle if low---pressurize, but be careful here, do not over max pressure or you can MAKE a leak: go just BELOW max pressure---let stand---if the pressure does not drop and coolant level stays the same, no leak---However, an IC leak would not explain why the fan did not come on. An IC leak would make the fan run LONGER than normal due to low coolant---the fan would try to compensate for the increase temp reading by running longer trying to bring the temp down---not the opposite by cutting off. Good luck. Jimmy
