Originally Posted by boocher13
thanks for all your help and info guys.I just spoke to the service manager and asked if the coolant level was low or was the light on for a fan failure and I was told it was not from low coolant it was because the fan was not kicking on.I then said this is a commonly misdiagnosed issue and she said the tech tested both the fan and the fuse.I asked if it was also low on coolant and she said no but didn't sound too convincing so for peace of mind I called the stealership I am buying it from and told the service manager there I want them to perform a coolant system leak down test.Worst case scenario I have to do the test myself and then take it back while its still under warranty I have a leak down kit here.
Just FYI---There is more than one fuse---also, temp sensor, bad fan, bad relay, bad ground and the list goes on for reasons why the fan would not come on; MANY checks BEFORE I would let my shop condemn a PCM---Still does not make sense to me, just THAT side of the PCM is bad, no other problems? But COULD BE!!! Again, if coolant is full = zero leak---you should be good, but check anyways---Still, low coolant would not cause an inop fan---overworked not inop. No matter what---My questions are---First, how long has this car been running without a GOOD fan?---Really, how long? You KNOW that it is not working; you do not know for how long. No fan = increased HEAT, and heat is bad for the motor---No matter what the reason---Also #2, if it is the PCM---How long has this car been running with a bad PCM and what other functions have been turned off (other than the fan) or running incorrectly? Rich/ Lean, what else? Think about it---this is a HIGH dollar car to repair at times---AMG parts are not cheap!!! Good luck, Jimmy
