Old Aug 6, 2011 | 10:12 AM
dinasrt's Avatar
dinasrt
Default Re: Intake gaskets... again!
NoNONO! That slippery blue stuff is going to get everywhere. The Copper coat is more like a tacky filler paint almost. Let it dry on the gasket, torque to 7ft pounds and be done with it! I pumped up my motor to 25psi no leaks. Yes, you get a slight discoloring around the edges of the gasket.
I'm hearing you Chris. Your testing to 25# w/ no issue says a lot. What are your thoughts on the "Copper"? Is it real copper in that spray? We don't need to worry about dissimilar metal? That was the only reason I was going to try the blue dressing (not to be confused w/ RTV). If corrosion is not an issue then I'll go w/ the proven copper spray method. Bob
