Re: Center Console LOCKED
[quote=BRappaport]Hi RMADERMAN,
Each key fob can be programmed differently. There are 2 programming modes. One mode locks the doors, but not the center console on the roadster. The other mode locks the center console as well.
Therefore, I believe that your key fobs are programmed differently.
Try the following two things to unlock your center console:
1. When using the key fob you have, hit the open button twice instead of once.
2. Try using the central locking system button that is located on the dash...under the radio.
Good Luck....Ben
__________________________________________________ ____________
RMADERMAN,
How did you make out with my suggestions for opening your center console?
BRappaport
