Old Aug 9, 2011 | 09:52 PM
James1549
Default Re: Headlight bulb - Replaced and not working
Originally Posted by tnhatch03
does it need the contact in order for the light to turn on? if so, that would explain the reason it would not turn on. i had the bulb out of the housing and just hooked up from the clip and turned it on.
I wouldn't think it should matter, but I haven't tried it. Using a test probe, you need to see if you are getting 12v and ground to the connector at the bulb.
