Old Aug 11, 2011 | 09:44 PM
grip grip's Avatar
grip grip
Default Re: Will these calipers fit. Expert help needed.
Originally Posted by JimmySkullz
No, the C32 are a direct fit, no spacers needed.. those you bought use a or around a 330mm rotor and need to be spaced out cause of the off set.
The C32/C55 and new SLK55 use a 4pot caliper with a 345mm rotor. a direct upgrade or the crossfire
So you viewed the front calipers in the link and I'm good to go with spacers, right? Thanks!
Do you have any idea where I can find the hardware?
