Old Aug 13, 2011 | 08:13 AM
grip grip's Avatar
grip grip
Default Re: Big brake upgrade info:
I passed on the setup yesterday. I'm on the fence on whether I'm going to upgrade them at all. If I do anything at all, I'll likely just get the calipers that are compatible with the 330mm rotors.
The more I looked into the upgrade the more I started to think it just wasn't worth the aggravation or money.
1 - With stock SRT6 wheels I'd need to spend $100 on front spacers and lug bolts. I would think spacing out the fronts and not the rears would look strange, so I'd have to do the rears also. So just spacing the wheels out to clear the calipers would be over $200.
2 - If I go with calipers requiring the 345mm rotors, that's another $250 at least, and most likely $300, since my stockers wouldn't work.
3 - From my searching the web this week I've seen the calipers selling from $150 a pair for the ones compatible with the 330mm rotors, and $250 for the C32's that require the larger ones. Those are the lowest prices I've found for either.
4 - The brake pads would likely need to be changed on the used calipers, so depending on preference that's $100 or more.
I just don't know if the extra leverage of the 345mm as opposed to the 330's would be worth spending the money on the larger rotors. Maybe the 330's would do just fine with 4 piston calipers. I just don't know.
Anyway, most calipers I've seen would require cleaning at a minimum, and rebuilding would be the best bet. If I have the calipers off, I might as well upgrade to stainless lines and change out the fluid.
For me, the deal breaker is the wheel spacers. If I discover that the CL500 and S500 don't require spacers since they are closer to the hub, then I'll do the upgrade. That would save me the $200 on spacers and $250-$300 on 345mm rotors. But as it stands right now, I just can't justify the expense.
