Re: need help installing new a/c drier and expansion valve
Your low side pressure is high because the unit is not pumping, Try to energize the compressor and dont open the system until you know that it is going to assist you. Dumping the freon and evacuating the system is not cheap or easy to do. Woody
I suspect a problem with the controls.
