Re: New Steering Wheel
Bringing up a dead thread, but I need some help. I scored an ultra-rare wheel from overseas (more details later), and Steve and I had a bear of a time trying to get the Allen bolts (yes, the very first step) off the back.
We were using a 4mm Allen, and with the long side inserted behind the wheel, we couldn't get enough leverage on the bolt to break it loose. Even tried gripping the Allen with a crescent wrench, and the bolts were so tight that the wrench was starting to bend (!!!).
Rudy suggested a metric T-handle wrench to get the job done. Metric, we did not have. Went to Sears and second-guessed ourselves, thinking that the T-handle might not have enough "oomph" to break the bolts loose. So we walked away empty handed.
Are we missing an extremely obvious detail, like turning the bolts the wrong way? I can't imagine the tiny little screws behind the airbag requiring 80ft/lbs of torque to break loose. If you're looking at the wheel from the rear, we were trying to turn the bolts to the left (counterclockwise) to break them loose. They wouldn't budge.
Needless to say, we didn't get too far and called it a day.
While we're asking, what size nut is the center of the wheel held on with?
Thanks Bob,
