Old Aug 15, 2011 | 01:21 AM
Kolme's Avatar
Kolme
Default Re: Need to run wires from license plate to inside of cabin with no drilling
Originally Posted by nox1s
Is this possible? I need to mount two objects on the back of the car (say the furthest left & right of the license plate in the recess) and run 2 wires into the cabin without drilling.. is this possible?
Has anyone done something similar to this?
Like this
Hmm, I have in the past took the power from each of the tail lights and routed the wires around the rear end and up into the trunk latch. You could take the wires from there and move them outside of the car to the spot you want. It wont be beautiful when you open the car but itll work..
You could also run the wires or pull power from the trunk hatch and run the wires out of the license plate lights i suppose? I'd be worried about water getting up into the lights though...
lastly, and i havent really explored this, you might be able to remove the rear plastic panelling the try and find an entry point there under the panelling.. but that doesnt sound like alot of fun...
goodluck!
