Old Aug 15, 2011 | 08:18 AM
onehundred80
Default Re: Need to run wires from license plate to inside of cabin with no drilling
Originally Posted by nox1s
Is this possible? I need to mount two objects on the back of the car (say the furthest left & right of the license plate in the recess) and run 2 wires into the cabin without drilling.. is this possible?
Has anyone done something similar to this?
Like this
Remove the door sill and the trim up the rear side of the door, pull back the carpet, take the foam plug out of the hole and you will see access holes to the trunk. Other wires are going through here so its easy to spot.
Remove the cover over the wheel arch in the trunk and you can pull a wire through, this works both sides of the car I believe, although I have only done it on the passenger side - LHD.
