Originally Posted by jmk41
Hey Eric I took my letters off using the floss and heat gun (careful you could ruin your paint!!) To remove the gunk I tried just as you did wd-40 then moved to some good ol 93 octane (gas) worked like a charm!! Dont mix the heat gun with the gas bad juju!! very bad juju!!
Hahaha....
I did everything except the 93 octane gas. If I knew where to find that I could try it... highest around here is 91 (at the regular stations at least) but I don't know where to find anything higher.
Thanks for the insight though
-Eric
