Old Aug 16, 2011 | 03:05 PM
almasyff8's Avatar
almasyff8
Default Re: Weird 2004 Crossfire Non Start Problem:
Originally Posted by onmark
Often, with the clutch depressed, turning the key won’t start the car. Dash lights come on but that’s it. However, it seems that if I release the clutch, depress it and then turn the key again, the car will usually start. Have replaced the Crankshaft Position Sensor with a Bosch unit and resoldered the relay control module terminals (they appeared to be ok - resoldered just to make sure). Neither of these things seem to fix the problem. Also, the key frequently locks up and won’t turn at all until you work it back and forth. Any ideas?
Maybe this...
key fix
