Old Aug 17, 2011 | 06:36 AM
maxcichon's Avatar
maxcichon
Default Re: Low Beam Head Light Adjustment
Originally Posted by OldSalt
Got all the info to adjust the RT head light. I tried to re position the low beam bulb but it did not help. It seems to be positioned properly.
If I adjust the the RT light won't that also affect the high beam?
My only other idea is to unhook the lock bale on the bulb and hook the connector and move the light in the socket and see if that will help me find the correct position.
The RT low beam hits only a few feet from the car but the RT high beam is fine. Left low/high beams are fine.
Thanks
OldSalt
It really sounds like the bulb is mis-seated. I had the same problem until I adjusted the seating by hand with the clip loose and the headlights ON. It doesn't get hot, so go for it. When it hits the sweet spot-you'll know it!
