Originally Posted by PNA
Yeah, I know what you mean about "too easy".......
Just make sure you slide the tools in the correct way (they should catch), pull it out straight (should slide easily), unplug the connectors and then clean the terminals.
Not sure how they could have gotten moisture but its good to check them.
Hope it works and clears up your issues.
ok if you don't mind, all came out great but going back in radio rides free and is not reaching a place where I can then REMOVE the right/left pull tools...any trick to sliding it back in for a good lock...and then I assume an easy removal of pulls?
